Early benchmarks suggest strong figures for AMD Ryzen 9 5950X
Written by Jennifer Allen
October 19, 2020 | 13:00
Tags: #leaks #rumours #ryzen-9-5950x
Companies: #amd
Everyone's favorite hardware benchmark leak detective, TUM_APISAK, has dug up some details and preliminary benchmarks for the AMD Ryzen 9 5950X. Predictably, it's looking very good indeed.
The roving sleuth has spotted a few entries for the AMD Ryzen 9 5950X on both SiSoftware and Geekbench and given the timings, we're guessing these are based on retail samples, although it's still worth being a little unsure of their accuracy.
Still, what we have seen looks remarkable. The processor features 16 cores and 32 threads with 64MB of L3 cache. It also has a 3.4GHz base clock along with a boost clock of up to 4.9GHz. That means a 100Mhz lower base clock than the Ryzen 9 3950X but a 200Mhz higher boost clock. Crucially, that's before you consider the switch from Zen 2 to Zen 3 which is set to revolutionise things.
In the SiSoftware benchmark, the Ryzen 9 5950X came back with a Processor Arithmetic score of 611.94 GOPS. In comparison, the aggregated score for a Ryzen 9 3950X is 562.11 GOPS so the newer chip works out at just under 9 percent faster with that benchmark. It gets better though with the Processor Multi-Media test suggesting a 25.2 percent improvement.
Remember we mentioned a Geekbench 5 benchmark too? That one is a little trickier to figure out because it looks like the processor has been substantially overclocked, as well as used alongside a Hackintosh setup as the benchmark was obtained on MacOS.
The processor has been overclocked to 6GHz, assuming Geekbench 5 hasn't made a mistake in detection. Still, if you compare it to the Ryzen 9 3900X when overclocked to 5.89GHz (like TUM_APISAK did), it's looking pretty good. Single-core performance comes in at a 19.2 percent improvement with a 12.9 percent higher multi-core performance. Obviously, this is when discussing a highly overclocked chip but we're hoping similar percentage gains are seen across the board.
For now, take all this with a pinch of salt as always. Still, the speculation is always entertaining while we wait for the official Ryzen 5000 series launch on November 5th.
Mod of the Month November 2020 in Association with Corsair
December 11 2020 | 17:30
