What is the best 600W+ PSU?
Following on from our recent round-up of PSUs below 600W, over the next few pages we're going to delve into the 600W+ bracket, reviewing ten PSUs rated between 600W and 750W, with prices ranging from £75 to £132.
As a PC is only as strong as its weakest component, there’s little point buying that expensive graphics card or CPU if your PSU doesn’t have the ability to power it. Many cheap generic models can’t even output their claimed wattage and are also often unstable, and a poor PSU can also cause stability issues, excessive electric noise or even component failure in extreme cases.
This roundup includes ten PSUs from a range of different manufacturers, and we've used our new testing methodology to sift the good from the bad.
*What is the best 600W+ PSU?  What is the best 600W+ PSU?
How We Test
Voltage stability is the most important factor in a PSU. Producing a stable voltage on each rail is a pretty tough task, and some PSUs simply aren't up to the job. This can cause problems, as some components may not start up if the voltage is too low, or could burn out if the voltage is too high. Fortunately, the Intel ATX spec lays down the physical and electrical characteristics necessary to adhere to the spec in black and white.
The ATX spec cites that there can be a maximum of 5 per cent variance (above or below) the voltage on the 3.3V, 5V and 5VSB rails, and up to 10 per cent variance on the -12V rail. For the 12V rails, the voltage can vary by up to 5 per cent.
As PSU test equipment is highly specialised, we use a third-party lab - in this case, the R&D office of Antec in Taiwan. By using a combination of a Chroma 6314 load tester, Chroma 61604 programmable power source and iDRC CP-290 power meter, we're able to measure the voltage stability, overall efficiency and PFC efficiency of each PSU.
To test each PSU, we programmed the load testers to drain the amount of power that each manufacturer claims its PSU can deliver. The voltage of each rail was measured at 10, 50 and 100 per cent load to determine if it was within the ATX spec. We then left each PSU running at 100 per cent load for 15 minutes to see if it could produce stable voltages over an extended period.
The equipment we use to test PSUs
We also carried out a ripple test, which is a measurement of the peak-to-peak difference in the amplitude of the 12V voltage waveform supplied by the PSU. All PSUs exhibit ripple, but lower results are better as high ripple can potentially shorten the lifespan of your components. As a point of reference, the ATX specification states 120mV for the maximum recommended ripple.
Finally we measured the hold-up time of the 5V and 12V rails. Hold-up is the length of time a PSU is able to supply power, taking into account small dropouts in the power supplied by the mains. These troughs only last for fractions of a second but can cause issues, so the PSU steps in and takes up the slack. The ATX specification recommends a minimum hold-up time of 17ms.
We also calculated the efficiency of each PSU. Efficiency is very important as any wasted energy is dissipated as heat, which the cooling system has to expel. If it doesn't do this well, the effectiveness of the electronic components inside the PSU will be reduced, or the PSU will burn out. An efficient PSU, on the other hand, will run cooler and draw less power from the mains, which will help to reduce your electricity bill. The ATX spec cites that, at full load, a PSU has to be at least 70 per cent efficient.
*What is the best 600W+ PSU?  What is the best 600W+ PSU? *What is the best 600W+ PSU?  What is the best 600W+ PSU?
Left: Chroma 61604 programmable power source and iDRC CP-290 power meter. Right: LeCroy WaveSurfer oscilloscope
The Scores
The voltage stability tests take pride of place in the scoring box and account for 40 per cent of each PSU's overall score. The scores shown are the number of test measurements that are within the limits of the ATX spec, converted into a percentage to enable PSUs with a different number of rails to be compared. We only recommend that you buy a PSU that has 100 per cent stability.
The Design score includes the overall efficiency as measured during the 50 and 100 per cent load test scenarios, the number, type and quality of the cables, plus the noise of the cooling fan(s) at 100 per cent load. The Design score also incorporates how little ripple we measured, and the length of the hold-up time.
Finally, the Value score is a combination of the Stability and Features scores and the total output (in watts) divided by the price. These three scores are then added together to give the Overall score of the PSU.
Mod of the Month November 2020 in Association with Corsair
December 11 2020 | 17:30
